how can I get my 3rd gen to hook?
Old Feb 25, 2003 | 02:52 PM
Camarokid01's Avatar
Alright everyone, I've got a 86 camaro with a well built motor and its got some serious traction problems, I have the eibach pro kit which I know makes traction worse, but I have the control arm relocation brackets and adjustable tubular control arms. What else would be a good investment in getting me some traction, I plan on getting some drag radials but what else? Torque arm, panhard rod? what else?
Thanks in advance
Old Feb 25, 2003 | 04:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Torque arm so that you can adjust the pinion angle.
You already have good LCA and the relocation brackets. The LCA should be parallel to the ground or down slightly at the rear.
You could get air bags inside the rear springs. One is all you need in the passenger side spring. About 15 pounds of air helps keep that wheel from rising off the ground under hard accelleration.
A rear sway bar also helps do the same thing.
Lastly the biggest thing to improve traction is slicks.
The panhard bar is nice to have but only really helps on cornering since it's designed to keep the diff centered under the car. Straight line accelleration won't cause the diff to go sideways.
Old Feb 25, 2003 | 05:11 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
How about the SSM machine kit?
https://www.thirdgen.org/techbb2/sho...7&goto=newpost
Old Feb 25, 2003 | 08:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I don't recommend it because you can't adjust the pinion angle.
Old Feb 25, 2003 | 08:53 PM
87transam5.7tpi's Avatar
I would get some SFC's too before you start hooking hard, you dont want to bed the crap outta your frame.
Josh
Old Feb 26, 2003 | 04:00 PM
Sorry I forgot to mention I already have subframe connectors, what brand torque arm do you recommend Stephen? I have SPOHN control arms, brackets, and subframes. And I also want an adjustble torque arm correct?
Old Feb 26, 2003 | 04:11 PM
Sorry forgot to ask, do you know if an air bag will fit in my eibach pro kit springs?
bjpotter
Jan 22, 2019 12:27 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
