Reinforced stock LCAs?
Old Feb 26, 2003 | 04:27 PM
Bjase's Avatar
Car: 88 IROC
Never seen anyone else mention it... My lower control arms have a flat bar with the ends bent to a pipe shape inside them. 2 bolts go thru the LCA, thru the round ends, thus trapping the bars in the middle of the "U" shape of the LCA.
Is this common? I noticed them when I was gonna take the LCAs out to box them. Seemed like I'd just be wasting my time.
Old Feb 26, 2003 | 05:33 PM
Marc 85Z28's Avatar
I think most if not all cars had that. I know mine did, and nearly every other I've seen, including the V6 cars. But still that "reinforcement" isn't that strong. Check out Lakewood's LCA's, they're only $75! That's half of what most other companies charge. They're powdercoated, come with greaseable poly bushings, and make a noticable difference in wheelhop.
Old Feb 26, 2003 | 06:15 PM
Bjase's Avatar
Car: 88 IROC
Oh, yeah. I've been eyeballing a couple of different aftermarket arms. I'd like a set that uses the same size bushings as stock, considering I've already got polygraphite ones installed. Heck, the ones that come with 'em would probably outlast my poor car, anyway!
Back in the day I had an 84 Firebird that did not have the reinforcements, and I've got a rear from an 84 Z28 that doesn't have them. I was wondering if they were part of a suspension upgrade. My IROC is such a pieced together mess, there's no telling where they came from.
Old Feb 27, 2003 | 01:42 AM
MdFormula350's Avatar
i was thinking boxing my stock ones from my 88 iroc-z parts car however, i am thinking just buy aftermarket lca's for my 91 formula.
Old Feb 27, 2003 | 09:30 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
slp sells a set like them , i have them. but they are 1LE that are reinforced, they hookup a little better than stock but not worth th cash, i'm looking at tublar spohn ones. should be alot better.
Old Feb 27, 2003 | 10:06 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Think about suspension bind before you order your parts (or at least the type of joints on the LCAs).
Old Feb 28, 2003 | 08:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Reinforced stock LCAs?
Are you referring to the rear trailing arms? If so, it sounds like someone obtained the inserts used when putting a sway bar on a G or A body car. On those cars the rear sway bar is bolted onto the trailing arms. To prevent crushing the arm an insert is used.
RBob.
Old Feb 28, 2003 | 09:47 AM
Marc 85Z28's Avatar
Re: Re: Reinforced stock LCAs?
RBob.
No, he is referring to the reinforcement inside the rear LCA, or rear trailing arms as you call them. Has nothing to do with a G/A body car.
Old Feb 28, 2003 | 10:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Re: Re: Reinforced stock LCAs?
Would you happen to know if your car came from the factory with the inserts? I know that the '92 I have did not. And I know of a bunch of others that do not have the insert. It would be interesting to find out that some f-body's did come with them. Sorta' like the wonder-bar. . .
RBob.
Old Feb 28, 2003 | 01:58 PM
Marc 85Z28's Avatar
Yup, they are factory. And like I stated before, EVERY Thirdgen I've ever seen in a junkyard or other had them. Every single one, including the V6's. I was told that it was only offered on some cars by several board members long, long ago - like pre UBB Before the white background even. Back when the background was black and the text white. Replaced mine with the Lakewoods and look what I found Ever since everytime I go looking for stuff in the yards or we have a thirdgen in our dealership, I take a look. Every one! I could probably take pics of mine. Or you could even have them if you want. I have no need for them.
Old Mar 1, 2003 | 02:30 PM
Bjase's Avatar
Car: 88 IROC
Thanks for the input, everybody. RBob, they are pretty much like the G body inserts, just there for a different reason.
Marc, EVERY one? I can't say that I've looked at a lot of 'em, but I have 2 sets laying in my yard that don't even have the holes drilled in them, if I recall correctly.
Interesting.
Tubular bars are in the near future.... when the weather breaks and warmth returns!
Old Mar 1, 2003 | 05:59 PM
84s/e's Avatar
Car: 1984 Firebird S/E
Engine: 5.0 lg4
Mine don't have the inserts either. And recently I bent one of mine and so I got one off an 84 Z at the junk yard and it didn't have the insert either. The original one on my car still doesn't have the holes drilled in it but, the one off the Z does.
Old Mar 1, 2003 | 09:37 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
I've only seen the reinforcements on camaros.. never on a bird. My 87 formula ws6 did not have them. But I got a set from an 86 Z that did. And I have seen them on v/6 camaros too.
Old Feb 7, 2011 | 02:10 PM
Staged84's Avatar
Car: 84 Z28
Engine: L69
Transmission: 5 speed
Boy- this is an old thread, but I finally found it. I have an 84 Z28 that came with the reinforcements and a 91 RS that definitely does NOT have them. I thought it might be a Z28/Base model thing- but evidently not.
Old Feb 7, 2011 | 02:35 PM
Stephen's Avatar
Car: 87 GTA
I'd love to see the reinforcements he speaks of. I have 4 LCAs off 2 GTA right now & none of them have anything inside. I've had RSs, Z28s, IROCs......NONE of them had ANYTHING inside the LCAs, nor have I ever seen a stock LCA with anything reinforcing it.
Anybody got a pic of LCAs like that?
Old Feb 7, 2011 | 02:49 PM
I've never seen anything REMOTELY like that either; and I've looked at em in junkyards from one end of the country to the other. Not 3rd gen or 4th gen (same basic part). My own didn't have it.
The OE ones were so flimsy, I could bend them with my hands. I threw em in the trash and put in the Lakewood ones that are square tubing with poly bushings, since they were SO CHEEEP. Just one piece in a long chain of taking floppy rubber-bands out of my suspension.
Old Feb 7, 2011 | 03:34 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following info is from my 82-91 Parts & Illustration Catalogue (note the part numbers):
Number 21 below: REINFORCEMENT, Stab Shf Lwr Cont (1983-86)
Number 22 below: BOLT, Hex (M10x1.5x55)
What cars were equipped with the reinforcement piece I'm unsure, but they were available.
For the PDF files of the above, see the link below:
https://www.thirdgen.org/forums/susp...ml#post4997928
JamesC
Old Feb 10, 2011 | 10:28 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Here is a set of braces from a g-body ('87 regal Limited). Holes are on 5.5" centers. Sway bar is to the right in the picture (end that bolts to trailing arm). Note that the g-bodys of that era use the same trailing arms as the 3rd gen f-body's. With the exception that not all f-body trailing arms have the holes.
RBob.
Old Feb 10, 2011 | 10:35 AM
Stephen's Avatar
Car: 87 GTA
RBob.
Those are the braces that went inside the arm & was bolted in place?
I've heard of them, but never seen them.
Old Feb 10, 2011 | 12:00 PM
I've had plenty of braces like that in G-bodies, A-bodies, and B-bodies, as far back as the 60s. Never seen em in a F-body. OTOH if G-body LCAs fit F-bodies (which I don't know, but wouldn't surprise me in the slightest), then that could easily explain how they got there.
Old Feb 10, 2011 | 12:57 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, they are stamped heavy gauge sheet metal with the ends rolled for bolt holes. The bolts are long as they also clamp the sway bar to the trailing arm.
Personally, I've never seen them used except in conjunction with a sway bar. But as others have seen, GM apparently did use them in f-body's w/o the sway bar. I would imagine as a stiffener for the trailing arm. Which makes sense.
RBob.
Genopsyde
Oct 7, 2015 08:35 PM
TheExaminer
Aug 25, 2015 07:34 PM
TheJoeY88
Aug 13, 2015 06:51 PM
NBrehm
Aug 5, 2015 07:57 PM
