Brakes grabbing hard easily.
Old Mar 3, 2003 | 06:08 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
When Im at low speed, idle even my brakes grab really hard when I just barely touch the pedal. At speed they've been fine... but I havn't gotten the car up to speed lately as I've been just working on it... they were a bit grabby before but seem to be getting worse and worse quickly. I should mention that I've also only had it running for a couple minutes at a time and its always been at high idle. Are some of my lines collapsing or whats up? Oh also the car stops straight, no pulling. just hard/sensivitve brakes at idle basically and it's the fronts only. I have rear drums.
Old Mar 3, 2003 | 10:26 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Re: Brakes grabbing hard easily.
Sounds familiar- brakes grab hard and are extremely touchy?- front end dives down hard?- real pain in the *** to drive smooth at low speed like iin stop and go traffic?
Answer- You rear brakes are not working because the proportioning valves for these drum cars are crap- do this mod and they will feel much better-
https://www.thirdgen.org/techbb2/sho...hreadid=127100
Old Mar 4, 2003 | 02:57 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
so all I need do is take out the stock proportioning valve plug and stick in an allen head plug 5/8"-18 x 1/2"long? I'm not that familiar with where this plug is however I'll get the help of a friend who knows to try it.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
