Help, 3rd gen, 4th gen brakes
Car: 91 Z28
Transmission: 700 R4
hello, i am puttin a 4th gen rearend, in my thirdgen, the rearend is complete except for the brake setup, its just the rear with the 4 bolts at the end of the axels, will my 3rd gen brake drums, and internal guts bolt up just fine.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
What year rearend did your thirdgen brakes come off? If it was an early rear, I seem to recall something being different about the rear drums. If they came off a later thirdgen rear, then I would guess that they should bolt up fine. You'll prolly need to re-use your thirdgen brake lines though, might take a little bending for the additional 2" per side.
Car: 91 Z28
well the 4th gen is off of a 97, and the 3rd gen is off of an 87, thanks, and i will be selling the thirdgen if anybody wants it thaks dan
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
