Need some help with sizing of ET Streets
Old Mar 13, 2003 | 02:09 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
I've did a search on here. Pretty much figured out that running a 15x8 with a 27 or 28x10.5 will work no problems other than being very close if someone you run a rear disk system.
I was thinking about running a 15x10 and trying to fit a 27 or 28x11.5 or 12.5 but hopefully not having to do any modifications to the wheel well. Also, both would use a 5.5 Backspacing.
Lastly, if the combos above do work, does the tire stick out at all or will it look for the most part normal.
These will be used for track only.
Old Mar 13, 2003 | 09:05 PM
Ions91Z28's Avatar
ttt
customblackbird
Oct 1, 2015 04:30 PM
Linson
Sep 21, 2015 01:08 PM
rb85TA
26
Sep 14, 2015 10:29 PM
Doobie52
Sep 11, 2015 06:19 PM
m00n420
Sep 11, 2015 02:39 PM
