spherical rod ended??
Old Mar 13, 2003 | 04:52 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
What am I gaining and loosing going from Pollyurthane to spherical rod ended bushings? I am redoing my suspension and I noticed that on spohn's site. Thanks. Oh and if I don't have adjustable LCA's is that gonna effect anything if I lower my car 1.25"? Cause I have the adj. panhard bar, relocation brackets and I am gonna have adj. torque arm too but I just have 50/50 Lakewood pollyurthane LCA's, non adjustable. Thanks
Old Mar 13, 2003 | 06:44 PM
CrazyHawaiian's Avatar
Car: too many ...
Spherical Rod Ended bushings will have less flex and binding than Poly bushings. The tradeoff is that the ride becomes harsher and road noise increases. It is recommended for race applications. Poly is recommended for street use.
Old Mar 13, 2003 | 08:14 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I just installed my new panhard bar I made with rod ends last saturday. I've got a flowmaster cat back and wasn't sure if I would get more road noise or not. But with my fairly loud flowmaster, I can't tell any difference in road noise. I am able to hear a loud clunking noise when cornering hard over the uneven surface of the area we run our events while running race tires. The solid ends transfer the noise to the car pretty badly, but in normal driving I can't hear or feel any difference at all. But the car did seem more stable to me with the new bar and solid rod ends.
Next I'm putting on LCA relocation brackets and going to make some adjustable LCA's with rod ends. I own a machine shop and I can make stuff like this for a fraction of the retail cost. And if I don't like the solid end LCA's it's an easy swap back to the stockers.
Anyway just my .02 worth.
Old Mar 13, 2003 | 08:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Spherical ends also wear out. On a daily driver, they should be changed every few years.
Old Mar 13, 2003 | 08:21 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Alright, thanks guys. Looks like i am going with the pollyurthane pushings.
Old Mar 18, 2003 | 09:41 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
eric...go with poly. as long as you keep them lubed up (which i know you will, right buddy? ) you'll be fine.
i got the LCAs and panhard rod with all poly...but went with a spherical rod end on my torque arm.
-Brian
Old Mar 18, 2003 | 04:54 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Thats what I had for my line up was all polly expect my torque arm was gonna have spherical rod ends. For the extra 15 bucks I thought it might be worth it.
And yes, I keep her lubed. You know what I'm talkin about. :lala:
Old Mar 18, 2003 | 11:14 PM
Kandied91z's Avatar
those springs you really won't have to do much adjustment, you shouldn't even really need the relocation brackets.
even the panhard shouldn't have to be adjusted much unless your rear is off to one side.
drop down to 2" or more though and you'll definately want the relocation brackets and 2 way adjustable lca's and panhard.
Old Mar 19, 2003 | 06:45 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Hey Jeff, whats up? Hows the new crate engine treatin ya?
Old Mar 20, 2003 | 12:41 AM
Kandied91z's Avatar
crate engine.............don't know what your talking about. the little H.O. 350 is doing good.......just waiting to be broken in.
Old Mar 20, 2003 | 06:37 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Hahaha, 350 H.O. huh? Hmmm, I think I know otherwise.
"385"
thats all i will say.
mantaguy
Sep 1, 2015 08:39 PM
gixxer92
Sep 1, 2015 04:32 PM
Thaney9
Aug 29, 2015 03:16 PM
zayne0
Aug 24, 2015 07:22 PM
