Alignment
Old Mar 15, 2003 | 08:20 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Alignment
I've looked at a lot of posts on this and I'm going to try the following: -.7 camber each side, + 4.5 and +5.0 caster and 1/16 toe.
The car is an 83TA, with Prokit, Koni Yellows, Adjustable Panhard, Adjustable LCAs and LCA relo-brackets.
Also has 275/40/17 wheels and will be used for agressive street as well as lap days at a road race course.
So, will those caster settings be OK with the 17 inch rims or should I go more and is the toe setting about right for this application.
Thanx
Old Mar 16, 2003 | 04:09 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
caster will be fine. toe i would use around 0.03* total toe.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
89 formula TPI
Sep 20, 2015 10:54 AM
