will new front springs fix this?
Old Mar 19, 2003 | 08:03 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
as you guys can see the front lift is bad and thats due to the previous owner putting bad springs in it.. i want to know if my 16's will rub with it lowered bacvk to stock hight! they dont rub now thanx
Old Mar 19, 2003 | 08:29 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Re: will new front springs fix this?
They shouldn't rub. When I got my car I had no rubbing and that was with the stock springs that were sagging a little. I had to replace the front springs with new stock IROC springs after cracking one when my car decided to take off while thinking that the Knight Rider turbo boost was an RPO that she has. Anyhoo, even with the new springs I had no rub.
You will have no rubbing.
Robert
Old Mar 19, 2003 | 11:00 PM
llvll4l2c91350's Avatar
most likely they won't rub, but even if they do I'd still go ahead and lower it. it definitely needs it.
Old Mar 20, 2003 | 09:51 AM
TransAmTBI's Avatar
Engine: 305 TBI
actually it rubs on right turns... i might cut out the little piece of metal that is sticking out of the fender that is hitting the tire..
the reason i asked is because the caR Originally had 15's
Old Mar 22, 2003 | 11:42 PM
Spdfrk1990's Avatar
My wheels use to rub until i replaced the ball joints
Old Mar 23, 2003 | 09:52 AM
TransAmTBI's Avatar
Engine: 305 TBI
maybe i'l look into that thanx
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
TheExaminer
Aug 25, 2015 07:34 PM
TA8487
Aug 11, 2015 09:02 PM
