Wheel stud sizing...
Old Mar 21, 2003 | 01:55 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I am needing longer wheel studs for both front and rear, have any of you replaced yours with longer ones, such as ARP or Moroso? If so, what size am I needing? I have the standard disks in front that came on the car (1991) , just aftermarket rotors, the rear has the PBR disks from an 89 IROC . Thanks for any help, I tried a search, but came up with nothing answering my question.
I will attach some pics showing why I need the extra length..
Old Mar 21, 2003 | 01:56 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
As you can see, the lug nuts only go on a few threads before the wheels are tight... No, I do not have spacers....
Old Mar 21, 2003 | 02:35 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I haven't replaced my studs yet, but it's my to do list. I did find a link to some studs and lug nuts that Ground Control offers. The studs are $2.50 each, and the matching lugs are $1.25 each. They are 1/2", and not metric.
Here is a link to their web page. After you get there, go to catalog, then camaro. The studs are about half way down the page.
http://www.ground-control.com/index.html
Old Mar 21, 2003 | 02:37 PM
383IROC's Avatar
I am having the same problem with my PBR rear disk brake setup. I had my local speed shop order some longer ARP studs for me and they should be in tomorrow. I will let you know how it goes.
Old Mar 21, 2003 | 04:48 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
I did a link on this a few months ago- just finally posted a finished picture with the lugnuts on. I forgot to finish that link but its done now.
https://www.thirdgen.org/techbb2/sho...hreadid=156235
New2Chevy
Sep 28, 2015 12:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
