can rear spring be installed wrong?
Old Mar 24, 2003 | 12:49 PM
zee28's Avatar
Car: 86 iroc
I just had a shop swap rearends in my 86 iroc.Everything seems fine except for a pop or clunk coming from the rear only when I turn left or hit a sharp bump going under 30mph.The noise wasnt there before but these fools messed up one of my wheels so bad I wount take the car back.It sounds like a spring is moving around or popping.The noise seems to be on the passenger side rear.If I rock the car side to side in the rear sitting still I can just barely hear the noise.Everything I can see is tight.Maybe a spring isolator? they reused the old ones.thanks
Old Mar 24, 2003 | 01:05 PM
BTS88IROC's Avatar
Are you sure they put the spring isolators back in? Also check your wheels and make sure they aren't loose or something.
Old Mar 24, 2003 | 02:34 PM
zee28's Avatar
Car: 86 iroc
from what I can tell with the car on the ground,the spring seats are in there.All the wheels are tight.
Old Mar 25, 2003 | 07:48 AM
zee28's Avatar
Car: 86 iroc
my problem was a broken sway bar end link on the pass. side rear.I did a search and found someone else with the same problem,went out and looked again and sure enough the bolt is broke.
Old Mar 25, 2003 | 07:49 AM
z28bill's Avatar
Car: 1987 Camaro
Engine: 383
Transmission: Built Up 700-R4
I just did a rearend swap yesterday and have the same problem. I KNOW everything is tight, and I know I installed the springs with the insolators on them. I was going to check today and make sure the springs are seated correctly.
Old Mar 25, 2003 | 03:17 PM
BTS88IROC's Avatar
I thought you just said you found your problem? Wasn't that it?
Old Mar 25, 2003 | 08:32 PM
zee28's Avatar
Car: 86 iroc
yeah I found my problem(end link),It was someone else with a similar problem
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
dhonda200
Aug 11, 2015 11:50 PM
