rear trailing arm question
Old Mar 31, 2003 | 09:16 AM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
I am upgrading the rear suspension of my 91 RS. I am lowering the car by about 1.5 inches, installing an adjustable panhard bar and also I want to get new trailing arms. If I get nonadjustable trailing arms do I have to get the relocation brackets for them or can I just get adjustable trailing arms instead.
Old Mar 31, 2003 | 09:23 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the brackets have nothing to do with the length of the control arms, you will want to get brackets , then the arm is up to you.
even with an adjustable arm, the geomitry will be off, if you get the brackets that will correct the rear geomitry.
Old Mar 31, 2003 | 09:41 AM
iggy1991's Avatar
Which relocation brackets would you recommend?
Old Mar 31, 2003 | 09:43 AM
Dewey316's Avatar
Car: 1990 Camaro RS
i have the spohn peice, they are all basicly the same. if you can get a weld in set. if there is no way you can get them welded, BMR makes a bolt in set, but i would go the weld in route (spohn)
Old Mar 31, 2003 | 09:55 AM
iggy1991's Avatar
http://www.installuniversity.com/ins...n_brackets.htm
This is a web site that shows how to install them. Why is it necesary to get these brackets?
Old Mar 31, 2003 | 09:57 AM
iggy1991's Avatar
Oh, I understand. Nevermind, thanks for the help.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
