professionally made custome SFCs...need suggestions (did a search...)
Old Mar 31, 2003 | 09:21 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i was talking to a buddy of mine who has had a lot of fast cars (usually 5.0s, but whatever) about getting SFCs welded.
he says he knows a guy that is amazing at doing that type of thing, but he told me NOT to buy any, because he will make them himself just for my car. now, this guy does full roll cages in cars, and makes all kinds of crap for mustangs, etc. as far as custom rear suspensions and things like that, so i know he isnt some schmuch off the streets that just got a welder from sears.
knowing how well pre-fab SFCs work and fit (i.e. Spohn), should i just ask him to weld them up, or should i let him do whatever he wants and custom make SFCs? price isnt really a concern i dont think...i guess he is pretty resonable.
what do you guys think? i have had my mind set on the Spohns for a while now, but this may be a different way to go.
what should i look for in a custom job? any pitfalls i should be aware of? i just want to know what i may be getting into.
thanks...
-brian
Old Mar 31, 2003 | 10:59 AM
ede's Avatar
ede
you don't have to work for nasa to make SFCs. go with what you like and is most cost effective.
Old Mar 31, 2003 | 03:51 PM
CaysE's Avatar
agreed. the custom job will probably cost more, but not by much. go with what works for you. the Spohns are a great fit.
Old Mar 31, 2003 | 05:24 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
I had mine custom made, and I am very happy with them. They costed me cheaper than buying frame connectors and having them installed, and to be honest I think they aer probably better than anything you can buy. That's just me though! Here are a some pics ....unfortunatley they are the best I have for now!
Old Mar 31, 2003 | 06:55 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
im about to do my own took my measurements yesterday gettin them made this week and welded in in a couple of weels im makin mine just like the spoons, and all of it for free pays to work with welders and such
Old Apr 3, 2003 | 03:17 PM
MdFormula350's Avatar
i had no problem spending 185 bucks on the spohn sfc's, i know they will work just need to get them installed some time.
Old Apr 3, 2003 | 11:06 PM
DukeofBird's Avatar
it will most gifenetly be cheaper to have them custom made, cause they will probably use 2x2, or 2x3 tubing, and for the length that they need to be to go from rear subframe, to front subframe, will probably be no more than 12ft total of tubing, but if you get custom made sfcs, they will probably have to run through the floorpan to be done right.
Old Apr 4, 2003 | 02:47 PM
camaroguy2003's Avatar
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
I custom made my own using 2"x2" tubing. It did not require notching the floorboards. Theyre are some places that need ground off so that they are flush but other than that it's a real simple job. Suspension parts aren't hard to make if you have the tools and ability to do it right, it just takes some thought to make sure that you have it the way you want it.
Old Apr 4, 2003 | 03:02 PM
DukeofBird's Avatar
oh well that is even better, havent really looked at where im gonna run mine, but im also gonna use 2x3x.0625wall thickness(maybe.125 wall thickness), when i do mine
Old Apr 6, 2003 | 10:40 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Hey Brain,
Who does Subframe connectors in Syracuse
Old Apr 6, 2003 | 11:23 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Originally posted by Anth's Iroc
Hey Brain,
hey man...long time no see.
im not sure who it is...its a friend of a friend. i know of a few different people that do them...but its all the same situation...i dont know them personally, i just know how to get a hold of them.
if you are interested in getting them, let me know..i can dig up some names for you.
-brian
Old Apr 7, 2003 | 09:33 AM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Thanks Brian
Ill send ya some email .
Old Apr 7, 2003 | 07:11 PM
colonboy14's Avatar
Car: Trans Am
If your car has been in a wreck in the past, even if it is fine now, get them custom mode. If not, I would go with pre-fabbed.
Jeremys87
Jul 14, 2022 09:08 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Americanmouse
Sep 7, 2015 12:10 PM
formula_novice
Sep 5, 2015 03:58 AM
kah992
Aug 19, 2015 02:55 PM
