quick question about boxing in LCA's
Old Apr 2, 2003 | 04:17 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
I already cut my metal and stuff in my welding class that I need to box in my LCA's I was planning on boxing them in, tomorrow at school during my welding class, but my question is: is it ok for the car to be up on a jack? I know installing sub-frames it is best to have the suspension loaded when you do it, will this cause any problems if my car is up on a jack when im boxing the LCA's in? thanks
Old Apr 2, 2003 | 07:49 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
nobody knows?? I know people have done this, I just dont wanna screw up my suspension or something because the suspension wasnt loaded when I welded them in.
Old Apr 2, 2003 | 08:20 PM
camaroguy2003's Avatar
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
I would pull the LCAs off of the car to box them. This makes it easier to weld and it must be done to paint them anyways. I pulled them off and welded them on my welding bench and then primed and painted them, and reinstalled them. They work great. At the same time I boxed my panhard rod. I also fabricated my own subframe connectors, lower control arm relocating brackets, and strut-tower brace. You just can't beat making your own parts as long as you have the tools and the skills to do it right.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
