question about peformance gain with the addition of a STB??
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I have a 91' camaro with the following
-poly components all around
-Bilstein shocks and struts
-Spohn SFC
-wonder bar
how much of a difference will the addition of a STB make?? Little or a lot??
-Spohn SFC
-wonder bar
id say go for it, i am going to get my sfc's installed most likely next week, and then i will install my wonderbar and the put on my stb..
the chassis should be alot better off than in stock form.
i figure any where in the front where the engine is could use extra support, so thats why i bought the stb and wonderbar.
One of the first upgrades I made was a Hothkis STB and the improvement was very noticeable. Second was Spohn Rear LCA's
& Pandard Bar again a improvement over the stock items. And finally Spohn SFC's and this brought everthing together,
However it was the STB that got me thinking about tightening up the car.
Originally posted by CaysE
Would a STB affect under/oversteer at all, like getting a bigger front sway bar?
Originally posted by DJP87Z28
NO, all the STB does is tightens up the front end and give more support between the strut towers.
All I have to say is that my STB been on my car for over three years and my opinions are based facts. Not some theory from people who have no experience with this part installed. .
The benefits of the STB are well know, so why don;t you do a search on this subject.
[QUOTE]Originally posted by CaysE
LOL... I had a feeling it would remove some understeer, but wasn't sure.
Nice comeback, uk
[/QUOTE
What understeer did you have before installing a STB??? And you had a feeling.
Nice comeback, uk
[/QUOTE What understeer did you have before installing a STB??? And you had a feeling.
: DJP,
I don't particularly want to get involved in flaming here..all I can can say that in tight corners (esp. at low speed) a lot of understeer occured on my RS... Put my STB on, and most of that understeer at low and other speeds went away.
My opinion, that I think will be shared by most others with a STB....if you didn't get this benefit then you must be pretty tight elsewhere in your set up.
Car: '86 TransAm WS6
Transmission: Custom TH700R4
It's been noted that under extreme high-load cornering, that the tops of the strut towers move laterally, as much as 1/4 inch each. This plays havoc on your camber settings. The STB ties the towers toghether, and to the firewall, eliminating the flex.
Before you install your new STB, Take the car on an, off-ramp at speed, to really load the suspension. Then, go straight home and install your STB. Then take the car back on the same off-ramp, and notice the difference.
It profides a much better feel from the driver's seat.
Car: 1982 Z28
Engine: LC9
Transmission: AR5
: Thread
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
