wheel/tire size maxes and factory backspacing?
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
No reply on https://www.thirdgen.org/techbb2/sho...readid=171938, maybe someone here??
I did some searching and found the recent threads about the 10x15/27 hoosiers. It seems to indicate that with a 4.5bs will fit and a 10.5x15/28 will fit with a 5.5bs (and a little hammer). IS this about right??
What is the backspacing on most factory rear wheels?? like 20mm?
Well the OE backspacing on 16" wheels is +0 mm front and +16mm rear. But I've had no experience with slicks so I'm not gonna say thats what you should run. I think you should roll the fenders in the rear regardless.
Linson
Sep 21, 2015 01:08 PM
