Rust on SFC welds... suggestions?
Old Apr 19, 2003 | 06:00 PM
CaysE's Avatar
I noticed today that, probably because of the horrendous winter this year, the welds holding the SFCs I got installed not too long ago are rusting. It's probably just surface rust at this point (I hope... the car saw a LOT of salt this year). I want to know what my options are to get rid of this and prevent it from happening again, both DIY and where I could bring it to have someone else do it. Please help!
Old Apr 19, 2003 | 06:05 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I would sand off the rust and paint over the bare metal with POR 15.
Old Apr 19, 2003 | 09:11 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
A good undercoating would do good things for you. I am also always amazed at how effective drain oil is at stopping the progression of rust.
Old Apr 20, 2003 | 11:19 AM
CaysE's Avatar
OK, I did a little researching on POR-15, and it looks like I can apply this stuff right over the rust? I assume it would be better to sand it anyway, but I was just wondering if that's true. Has anyone had problems without the topcoat on it? The welds would be occassionally exposed to UV reflected off the ground, since it's not completely under the car. Also, is this stuff sprayable?
Thanks for the help
Old Apr 20, 2003 | 12:01 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Go with the POR (Paint Over Rust). As I recall, it is sprayable. I used no topcoat, and after a couple of years, there are no adverse effects.
JamesC
Old Apr 20, 2003 | 03:00 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
www.por-15.com
Use a wire brush to get rid of what rust you can and just follow the instructions. I LOVE the stuff. It'll never rust after you put that stuff on. Yes, it's sprayable.
Ed
Old Apr 20, 2003 | 09:51 PM
WillWood's Avatar
Car: 1966 Volkswagen Beetle
Engine: Flat-4
Transmission: swing axle
Get all the rust off there, and then put some spray paint on there and it should be fine
Old Apr 21, 2003 | 09:53 PM
CaysE's Avatar
Don't mean to ruin your idea of what you might think is safe on your car at the moment, but when I had the SFCs welded on, they used black spraypaint over the welds. that paint is long gone witha healthy coat of rust after only a few months.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
R13_Braz
Sep 18, 2015 05:00 PM
m00n420
Sep 11, 2015 02:39 PM
luvofjah
Sep 10, 2015 10:41 AM
