sway bars
Old Apr 26, 2003 | 08:48 PM
txhotRS's Avatar
sway bars
IF i replace the sway bars,, front and rear, do I need to get new bushings also ???
Old Apr 26, 2003 | 11:22 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
you dont have to replace the endlink bushings but hte bushings that are toward the middle and go to the subrame and rear end yes. (if the sway bar is a different size)
Old Apr 27, 2003 | 12:47 AM
ronterry's Avatar
Car: '94 Corvette
...also if your bushings look like mine (pic below) then yes...
The end links I do however recommend replacing. Many times the bolt begins to distort or bend. The end link bolts I replaced today (yes I replaced both front & rear sway bars, bushings, & end links today) literally broke the nut clean off when trying to remove them off the front. The rear, the end link bolts were bent.
Ron
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
