will 4thgen front end fit
Old Apr 27, 2003 | 09:29 PM
zcar8585's Avatar
will 4th gen front emd fit in my 3rd gen maro and if so will it improve handling
Old Apr 27, 2003 | 10:10 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Anything can fit with enough money. In fact, Fatal88 did it, but he changed the entire engine bay out to fit w/ the 4th gen strut mounts etc. Its basically an entire 4th gen mounted on the front of a thirdgen.
This is kind of sad becuase all reports indicate that the thirdgen front suspention is actually better than the 4th. Not sure why though.
Old Apr 28, 2003 | 12:02 AM
Momar's Avatar
The fourth gen front suspension uses shocks instead of struts. This was done in order to get a better ride quality. This is a lot of what hurts the handling. I have heard that the fourthgens have a slower steering ratio, but dont know that thats true. I know that I turned the wheel from lock to lock on a 93 z28 that my cousin bought for the drivetrain and it took 2.25 turns which is what the quick ratio thirdgens do.
Ben
Old Sep 27, 2003 | 08:58 PM
jaredi's Avatar
Car: 97 Z71
Engine: 350 Vortec
Does anybody ever crawl under the car and look at anything anymore? The 4th gens are equipped with factory coil-overs and upper control arms which give:
1. Better ride quality
2. Stiffer wheel rate
3. Gains in negative camber under compression (body roll)
4. INCREASED CORNERING ABILITY.
4th gen front suspension is superior. That is not to say the 3rd gen cannot be made to compete, but when you go to modding, 4th gen will give you better results.
Jared
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
