Help!!! Just Installed Dropzones
Old May 3, 2003 | 01:35 PM
pezz's Avatar
Car: 91CAMARO
Hello everyone, I just installed new dropzone lowering springs on my 91RS. My old springs were completely shot. I didnt expect to see a difference in the height when I was done, but there was. The car is actually jacked in the back now. It is a lot higher than before. Looks good so I didnt pay it much attention. I took it on a test drive and the rear is rock solid. So tight that it is jaring me going over speed bumps(creeping over em, not flying). Is this normal? Also, just for more info, I didnt have time to swap the fronts, dont know if that makes a difference or not. I am gonna do them tomorrow. Any ideas, or am I worring for nuffin? Thanks
Marcus Lopez
91rs
Old May 4, 2003 | 04:32 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
I dont know about dropzones...but I'm guessing that their spring rate isnt very high. Considering that a normal road race camaro runs about 250-300lbs in the rear. The Eibach prokit is about 175 or so in the rear. I'm guessing that a company thats more about looks would probably be pretty weak. How low did it drop your car? are the bump stops possibly bottoming out? try to check that.
Old May 5, 2003 | 03:49 PM
CaysE's Avatar
Re: Help!!! Just Installed Dropzones
Marcus Lopez
91rs
If the fender gap is anything more than 2 inches, something isn't seated properly, which sounds like a possibility considering you're having a really harsh ride compared to old sagged springs (which is pretty harsh anyway). Take a look in there and make sure the springs are in their isolators properly, and everything is where it's supposed to be.
Old May 21, 2003 | 12:24 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
yah man you got something screwed up going on, my springs are GREAT!!! Your shouldnt be jacked.... make sure they are in correct. And you bump stops have nothing to do with it.....theres no way dropzones will dottom out unless your runing them with no shocks!
Old Feb 3, 2004 | 11:36 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Maybe your rear shocks are toast??
I will be picking up a set of these springs soon. Hopefully it doesn't lower my car that much. I still have stockers. But who knows. But the price is right on the dropzones so I'm gonna give them a shot and see what happens.
Old Feb 3, 2004 | 08:57 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Click the link in my sig for pointers on a lowering spring install. You may not have the springs properly seated in the upper spring buckets. If you don't have them in right, the *** end will sit too high.
Take a look and post what you find. The fronts are a job but not too hard, just take your time.
Ed
Old Feb 3, 2004 | 09:35 PM
pezz's Avatar
Car: 91CAMARO
Hey guys thanks for the replies but this was about 9 months ago. I will admit to being a dum a##. I put the fronts on the rear. Ofcourse the fronts are stiffer hence the problem. I am glad that you guys replied. A lot of good info. I own a custom paint and body shop in houston tx. anyone need any work let me know.
Old Feb 4, 2004 | 07:16 AM
ebmiller88's Avatar
No offense intended here, but that's damn funny. I bet that thing was like a catapault in the rearend. Good to know you got it worked out.
Ed
Old Feb 4, 2004 | 09:02 AM
pezz's Avatar
Car: 91CAMARO
Ya the thing was jacked way up in the back. It was like i was riding a shopping cart with an engine.
Old Feb 4, 2004 | 02:11 PM
Transmission: 4l60e
Now that its fixed how are they? Did they drop the car to much?
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
kevyb1973
Aug 24, 2015 04:11 PM
