im installing eibach prokit springs soon. which spohn panhard rod be best for me to use to recenter the rear after the spring install? im guessing it obviously has to be one of the adjustable ones but which one? will the poly bushings make it really annoying while driving?
I have a Spohn adjustable panhard rod with poly bushings and i would recommend it. I have all poly bushings on my car and the suspension parts in my sig and i love how my car rides.
Quote:
thanks for the info...Originally posted by vjo90RS8
which one of his do you have?
there are a bunch available from him
http://www.spohn.net/index.cfm?fusea...&categoryid=12
thanks alot!!
~matt
As he said he has the adjustable with poly bushing.
Which is here: http://www.spohn.net/index.cfm?fusea...ct&productid=8
thanks, i guess i misread somethin, cause he did pretty clearly state that didnt heOriginally posted by BTS88IROC
my fault. thanksTGO Supporter
I have the poly/rod end combo. Less bind then the full poly, less noise then the full rod end.
Dish out the extra $20 bucks for the lighter & stronger moly option.
Don't do rod ends unless this is a race only car. It's beyond me why folks get the rod ends for the street. The rod end where never designed for long term endurance.
'Justins' poly/rod combo might be ok, just be aware there not ment to last 100000 miles.
Ron
Spohn - adjustable - rod ends ( It's a race only car
) - moly.
Ron
) - moly.i guess im pretty panhard rod illeterate. what is a "rod end" exactly?
thanks for all the help.
It's considered a solid mount, reducing deflection to almost zero meaning a consistent chassis & suspension geometry.
Poly's or rubber have a certain amount of deflection or movement, but dampen the road noise & live longer.
(see pic of rod end below)
btw: rod ends are not just on panhard's but many other suspension parts.
Ron
Ron
ahhh i see, thanks for the explanation
yeah i dont want that. i ordered the adj. poly bushed one in black made of the 4130 chrome moly
thanks for the help guys! i do appreciate it:hail:
thanks for the help guys! i do appreciate it:hail:Supreme Member
You'll like the moly, it's very light.
BTW: your not the only who has to put one in soon. I got mine yesterday...
Ron
Ron
Ron
awesome! cant wait to get all my parts. thanks for your help Ron (im guessing thats your name)Originally posted by ronterry
Ron
and everyone else!ugh i should of got the moly my parts r kinda heavy i didnt know the moly was lighter i just thought it was stronger
