Borg-Warner 9-bolt filler
Old May 13, 2003 | 05:36 PM
Rand's Avatar
Okay, Borg-Warner's 9-bolt from an '89 firebird (formula). The differential faceplate has a black rubber cap as shown below, which bleeds fluid. Is that the filler, even though it's halfway down the plate? If not, where is the filler, because none of the bolts on top feel quite right. Need help soon. Is my daily driver.
File Type: bmp
Old May 13, 2003 | 05:38 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yep, that's the only hole in the pumpkin. You gotta fill thru there. Miles @ www.9bolt.com can get you a new one.
Ed
Old May 13, 2003 | 05:40 PM
Rand's Avatar
Okay, so how the hell? I couldn't even get it to budge. Does that mean that I only have the fill the diff to have its capacity? That's the best the rubber stopper is going to do.
Old May 13, 2003 | 05:41 PM
Rand's Avatar
Lemme try that again. Does that mean that I only have to fill it to half its capacity?
:: shakes his head ::
Old May 13, 2003 | 11:57 PM
ebmiller88's Avatar
PMd ya.
Ed
Old May 14, 2003 | 02:20 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
The only problem with PM'ing is that we don't get to see your advice
Old May 14, 2003 | 03:18 AM
ebmiller88's Avatar
You are correct, here ya go:
You CAREFLULLY pry it out, or if you're refilling the diff anyway, just pull the cover off and push it out from the inside. That way you're less likely to damage it during removal. These things are hard to find at a local dealer, but Miles at www.9bolt.com has them. And yes, you only fill the diff halfway, until fliud starts to come out of the hole. It's not chock full of oil.
As an alternative and to avoid having to replace the thing should I tear it, I welded a Moroso bung on the back of it. Looks trick and was only about $20.
Here's a link to the thread with pics:
https://www.thirdgen.org/techbb2/sho...highlight=cover
Let me know if you need anything else.
Welcome to the boards!
Ed
Old May 14, 2003 | 11:22 AM
82camaro's Avatar
Car: 82 camaro SC
Re: ...?
Filling it to the hole is the capacity--you don't fill the whole diff case with fluid.
Old May 14, 2003 | 12:27 PM
Rand's Avatar
Fantastic. Thanks, guys. I'll let you know when (not if) I have more trouble. ;D
Old May 15, 2003 | 04:03 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Those rubber plugs harden with age and start leaking. Been there, done that. I went to the Chev dealer and they had a replacement for only a couple bucks.
The best way to get it out is to pull the cover then push it out from the back side. That way you won't tear it up. Replacement cover gaskets are not too expensive.
Old May 15, 2003 | 05:11 PM
ebmiller88's Avatar
Funny you should mention that. I went to Pep Boys to get a gasket for my diff. They wanted $11 for a Fel-Pro. Then I drove 3 blocks to Advance Auto,and they charged me $5.71 tax included for the exact same gasket.
Old May 15, 2003 | 08:31 PM
Spdfrk1990's Avatar
can you get a aftermarket cover for the 9 bolt i want a chrome 1 or an aluminum 1.Mine also leaks
86IROC112
Nov 7, 2015 06:50 AM
6speedIROC
Sep 13, 2015 01:29 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
scottmoyer
Sep 7, 2015 07:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
