How much do I weight?
Old May 18, 2003 | 03:38 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I've done some minor weight savings and relocating to my car. Right now it doesn't run and it has no springs. So I'm stuck trtying to guess at which Moroso trick front springs to buy. Anyone care to guess at my front end weight?
I have a
fiberglass hood
battery relocated
aluminum heads
no smog
no AC
no back seats
no sway bar
before the car weighed 3440 w/ me (160) in it. I have no idea what my front end weight would be. Please feel free to guess, b/c I'm almost to the point of guessing and giving up.
Thanks in advance
Old May 20, 2003 | 07:22 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
ttt
Old May 20, 2003 | 10:25 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
A/C 46lbs
Rear Seat 3.5lbs
Battery 25lbs???
Smog 10lbs
Aluminum Heads 40lbs???
Fibreglass hood 60lbs???
Few guess in there but you're taking a large amount of weight that's high up on the front end off your car which will should make a pretty big gain in handling. Unless you're only drag racing taking the sway bar off is a bad idea and the rear seats is kinda reaching. Better off just taking out your spare tire at the track before you run.
Old May 20, 2003 | 11:55 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
I am drag racing. Hence why I'm getting drag racing springs and have removed the sway bar.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
PurelyPMD
May 5, 2016 04:57 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
Damon
Sep 26, 2015 04:29 PM
HikoriYami
Sep 21, 2015 07:11 PM
