1LE brake Question can you
Old May 21, 2003 | 03:58 PM
SLP_GTA's Avatar
Modify the spindle on the car??? is it just cutting off an ear and tapping a hole, correct???
Or do you have to remove the spindle to properly cut and tap it. I really didnt want to remove it if I didnt have to, can someone give me an insight
Old May 21, 2003 | 04:05 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
I suppose it could be done. It seems it would be a bit of a PITA, but I've never tried it so I can't say for sure.
What I chose to do was pick up a second set of spindles and have them modified. From there I'm going to assemble all my 1LE parts and do a simple spindle swap when I install my 1LE brakes.
Why are you hesitant to remove the spindels?
Old May 21, 2003 | 04:39 PM
SLP_GTA's Avatar
Originally posted by BretD 88GTA
Why are you hesitant to remove the spindels? [/B]
Because I recently installed springs and struted the car, and the alignment set up sweet, so I didnt want to remove the spindle if I didnt have to
Old May 21, 2003 | 04:44 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You have to cut off both upper and lower ears, and be really careful on that upper cut since the strut will be soooo close. It can be done on the car but you'll have to be careful to get those holes drilled and tapped straight.
Good luck!!
Ed
Old May 21, 2003 | 04:47 PM
Car: Yes...
Hey, look at it this way - alignments are fairly cheap.
I can understand not wanting to have it re-aligned after just having it done. If your current brakes are still good I'd conitnue to drive the car for while and do the 1LE upgrade later. By then you'll be do for another alignment anyway.
Old May 21, 2003 | 07:32 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I don't know if you have bought your 1LE parts yet, but if you haven't read this post and save yourself some money by using C4 corvette parts instead.
https://www.thirdgen.org/techbb2/sho...hreadid=142115
Old May 21, 2003 | 07:45 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I did the mod with the spindles on the car. Wasn't difficult at all.
Old May 22, 2003 | 06:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I did as BretD: I simply bought a second set of spindles from the bone yard. By doing it in that fashion, I could also easily paint (POR-15) the spindles.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
