DIY boxing
Old Jun 4, 2003 | 07:53 PM
Wezzeles's Avatar
Car: Camaro
DIY boxing
Is it hard to box your own lower control arms, me and my friend have an oxy- gas torch and practicing welding right now, thinking about boxing them or would be just easier to buy tubes and make tubular ones. I know that u can buy them from spohn, but it's kind of cool boxing or making your own.
Old Jun 4, 2003 | 08:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Pretty easy to do either one.
I'd start by boxing the stock ones in, you can do that with them on the car. When you get good at what you're doing with the welder then you can make some. It's not the kind of part I'd like to get my welding OJT on.... after all, people can die when it fails (including you).
Old Jun 4, 2003 | 08:51 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I wouldn't even consider boxing the control arms with an oxy-acetylene torch. Its not going to provide a good, strong bond. '
BTW, it is not hard at all to box the arms. Just cut a piece of steel to fit on the bottom and WELD it in place. You could also make your own arms out of tubular steel. DO NOT try to use your torch to do this. It is only recommended to TIG weld on suspension parts. IF you are planning on using rod ends to attach to the frame and rear then you could make your own because you would not need to weld a sleeve for a bushing.
Basically, I am telling you to NOT use a torch to do any welding. Sure it could work but have you ever been in car when a suspension part broke... you don't want to be
Good luck
Old Jun 4, 2003 | 11:17 PM
bes217's Avatar
Could you use a MIG welder to do this. I have one of these but not a TIG welder.
Old Jun 5, 2003 | 08:42 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
MIG welding is okay as long as you are a competent welder. TIG welding is preferred because it allows greater control which can mean a more consistent weld. MIG process is okay though.
Old Jun 5, 2003 | 08:53 AM
82camaro's Avatar
Car: 82 camaro SC
A torch is for cutting, and a welder is for welding. But hey, that just me.
Old Jun 6, 2003 | 12:35 AM
TexasLT1's Avatar
Car: '92 RS
for boxing, a MIG is fine. I just boxed my LCA's and panhard with 1" and 3/4" angle respectively. If I were making something though, I'd definitely TIG weld them.
Old Jun 6, 2003 | 08:09 AM
IndyTruck's Avatar
Boy, I'm sure glad I wasn't alive back before TIG welding was invented. Cars, equipment and OH MY GAWD, even big buildings must have been so unsafe! And airplanes! Trains! Boats!
In truth, beginning in the 80s, parts of some cars were made with "high strength steel," which allowed the parts to be the same strength as regular steel, but thinner and lighter. High strength steel will crystalize and fail when heated the way a gas welder does. However, arc welding, MIG welding and TIG welding are all perfectly adequate for boxing your arms or anything else you might want to do. Well, it'd be tough to do bodywork with a plain arc welder, but other than that....
kevin
Old Jun 6, 2003 | 11:21 AM
Wezzeles's Avatar
Car: Camaro
Thanks, yeah it doesn't seem the gas welder is that strong been practicing a little bit. Probably not a good Idea to mess with that part of the suspension.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
