Brakes a bit soft after disk conv.
Old Jun 12, 2003 | 12:18 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Well I finally finished my rear swap and went from drums to disk. Now the disks feel a bit soft, was far more responsive with the drum brakes. Any ideas of what to do?
They seem to be working correctly, except for a slight leak from the bandio(sp?) bolt.
Also I was looking at front brake kits and the only ones I found was the 1LE fo Spohn and a single piston wilwood kit. Any other ones?
Old Jun 12, 2003 | 12:51 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You might be sucking air back into the system through that leaking banjo bolt...
Old Jun 12, 2003 | 03:24 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Did you swap out the drum prop valve for a disc or adj valve?
Old Jun 12, 2003 | 10:14 PM
Car: 92' RS
Engine: LO3
No I did not. I was told that the stock one (flat prop valve) would be adequate. I was talking to another car guy that said I should get an adjustable prop valve. Though I have no Idea what I should set it to.
Old Jun 12, 2003 | 11:49 PM
zimmstoy's Avatar
Car: 85 Iroc
Engine: 305 LB9
Since your car is a 92. The Drum Brake Prop Valve / Master Cylinder and Disc Brake Prop / Master Cylinder should be listed as identical part numbers.
Get your leaks fixed and bleed the system.
customblackbird
Aug 15, 2021 10:16 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Warlocksirix
Sep 3, 2015 12:26 PM
