Brake line sizes and some problems....
Old Jun 14, 2003 | 03:45 AM
89ProchargedROC's Avatar
I am re-routing the brake lines out of the master cylinder to go UNDER the steering shaft instead of OVER it. The reason why i am doing this is because i need to gain some more clearance by the steering shaft
The smaller lines are 3/16" and i didn't have any problems buying some brake line from the local parts store and splicing them in with some tube nuts/sleeves and some -3an unions
My problem comes with the line that goes to the rear brakes. I assumed that it would be 1/4". But it might not be...i took off the fitting and cut the line to splice in some line and the fitting that screws into the proportioning valve wont fit over the 1/4" line for some reason
if i tap it on it will, but it doesn't fit
Anyone know if the line is some special size or something?
this is an 89 IROC-Z with 4 wheel disk brakes with the PBR rears
Old Jun 17, 2003 | 12:59 AM
come on.....one of you have to know
Old Jun 17, 2003 | 10:53 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It may be metric....if the ¼ inverted nut won't fit over the tube, then it's 7mm. If it was 6mm line, the nut would fit.
You may need to search out some standard-to-metric adapters and the right size double-flare tool for the metric line.
Pete
Old Jun 17, 2003 | 11:16 PM
great......
Reddeath210
Oct 6, 2015 08:20 AM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
