sway bar link ends
Old Jun 18, 2003 | 05:24 PM
T-Top T/A's Avatar
Car: 85 Trans Am
Engine: 305 LG4
Transmission: 700-R4
Axle/Gears: 3.08
sway bar link ends
while under my car today( 85' TA ), I noticed the the sway bar link ends are leaning in. Is this normal?? I was trying to figure out how to straighten them, and could see how (sway bar is centered perfectly)
Old Jun 18, 2003 | 08:43 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Its okay, they are mounted in rubber, they are allowed to lean.
Old Jun 19, 2003 | 09:18 AM
(BR)G-Machine's Avatar
Get some poly endlinks, improves the function of the sway bard!
Old Jun 19, 2003 | 09:31 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the angle they lean at will also depend on the the location of the rear end.
if you had the car lifted by the frame rails, and the rear hanging, the endlinks will be in a diffrent potition then they are when you have a fully loaded suspension.
Old Jun 19, 2003 | 10:03 AM
T-Top T/A's Avatar
Car: 85 Trans Am
Engine: 305 LG4
Axle/Gears: 3.08
these are the front link ends, when I first noticed it ,the car was on the ground.I had the wheel turned and noticed them,then went under to see If I can fix them
1992rs/ss
Jan 31, 2025 05:10 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
