2 problems with brake pressing
Old Jun 18, 2003 | 10:10 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
ok, i have a 1986 Trans Am. 2 problems, one is when the brake is pressed the wheel turns to the left so you have to hold onto the wheel really good when braking; two my brake doesn't exactly start working until pedal is at least half way pressed. Any idea on what is going wrong with it. i mean i'm only a teenager and i don't have money to see what the problem is and then fix it.
Old Jun 21, 2003 | 08:53 PM
dale davidson's Avatar
well, i would seem to think that you need brakes
Old Jun 21, 2003 | 09:26 PM
ChaosRanger's Avatar
Car: 1984 F41 T-Top
Transmission: 5 speed
Car pulls ...
*Incorrect tire pressure - check tires
*Front end may be out of line - check for tire bolding on the sides
*Brake line(s) may be clogged
*Damaged shoes and lining - warped disk, oil on shoes or disk(s)
*loose calipers
Half way for pedel
*May have air in the line - bleed brakes
*Worn shoes - check for thickness
*Vacuum - check line for cracks
well this is what I could think of....
Old Jun 21, 2003 | 10:51 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Yeah thanks. I'll have to bleed the brakes for the half pedal ting and i might just have to check out the julting while i'm doing that.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
smooth
Aug 18, 2015 06:34 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
