front coil spring install
Old Jul 7, 2003 | 09:44 AM
silverpace's Avatar
Car: 82 Z28 Indy Pace Car
Transmission: 4L60
1982 Camaro Z28, front spring replacement. Replacing front springs with NAPA repklacements.
I know that we discussed front coil spring installs many times but I'v never seen if installing springs with or without the engine in makes a difference. I can't seem to get enough weight down on the front end to pop the spring into the pocket. Please help?
Old Jul 7, 2003 | 02:19 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
using a floor jack to push up on the control arm to compress the spring would need the engine weight or a couple of friends. iused a spring compressor to get mine in.it took about3 inches of compression to get them in. its a pain isn't it?
Old Jul 7, 2003 | 05:27 PM
Jeffbird's Avatar
i used a hoist.took no time...from and rears..done in about 45 mins..
Old Jul 13, 2003 | 01:54 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
use a floor jack under the control arm, once the car is on jack-stands. disconnect the ball joint, steering arm and sway bar. Then you can lower the jack and the spring comes out. This works because the weight of the engine will force the spring to collapse. If you don't have that weight (of the engine) you'll need to use a spring compressor to collapse the spring so it will fit into the pocket.
Old Jul 13, 2003 | 02:24 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Used an interal (to the spring) compression to squeeze the spring down small enough it would fit. Wasn't much fun to manuver into position. Was like holding a bomb waiting for it to explode if the spring compressor slipped.
Old Jul 13, 2003 | 06:44 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Here ya go:
http://f1.pg.photos.yahoo.com/bc/tar...c=ph%26.view=t
Ed
Old Jul 14, 2003 | 07:17 AM
silverpace's Avatar
Transmission: 4L60
Ed, Great link!
:hail:
Thanks for all the great info.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
TheExaminer
Aug 25, 2015 07:34 PM
TA8487
Aug 11, 2015 09:02 PM
