Okay, my suspension problem pretty much seems to be the steering box....
Old Jul 11, 2003 | 06:15 PM
05kcilS's Avatar
Car: 1991 Z28
Engine: 350 L98
My question to you guys, is their an aftermarket steering box that is really good, for the price and performance?
or should I just go w/ an Autozone/Advanced Auto steering box.
either way the cheapest one they have is 200 bux.
So i was basically going w/ the theory of if you are gonna replace it, might as replace it w/ something better.
Old Jul 11, 2003 | 06:19 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
I went with the AGR box a while back and wasn't all that thrilled with it. First the steering wheel was way off center, about 90*, and the feel to it was really light instead of that tight feeling I was used to. Then that car was wrecked (bent the steering knuckle) and I tried the same box in my next car. The wheel couldn't be straightened and there was way too much slop in it then.
Just my 2 cents.
Old Jul 11, 2003 | 07:18 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
My camaro has a very light feeling steering, I am used to my trans am that has some resistance to it, is the box in need of replacement????
Old Jul 11, 2003 | 07:20 PM
05kcilS's Avatar
Car: 1991 Z28
Engine: 350 L98
you know what.... I am probably just gonna take it the dealer. this is a serious problem when i feel unsafe driving it.... rather get it done right and pay an *** load, then to get it done halfassed and pay twice.
I'll think i'll give the dealership a call tomorrow. :lala:
Old Jul 11, 2003 | 07:22 PM
slowTA's Avatar
Car: '88 Formula
Thats not what I am saying at all. The AGR box uses a different internal pressure spring that makes it feel lighter in the wheel. The stock performance boxes use a spring/valve that gives a heavier feel to the wheel. It all depends on what both of your boxes started out at. If it started light and went heavy over time, or vice-versa, then I would say that it is near the end of its life. Otherwise I'll assume that it is OK.
Old Jul 11, 2003 | 08:45 PM
cd90rs's Avatar
Car: 1990 Camaro RS
Engine: 96 LT1
I bought my fast ratio box here. Life time warranty.
Old Oct 4, 2003 | 09:31 AM
derrickk's Avatar
What kind of effort is involved with replacing the steering box? I got an '85 with about 160000 miles. I just rebuilt most of the front, and my steering box seems to have a lot of play. Too much for my taste and more than it used to.
Old Oct 4, 2003 | 09:38 AM
slowTA's Avatar
Car: '88 Formula
The hardest part is to pull apart and reconncect the power steering hoses. Once you manage to get them out, getting them to line back up is a chore. It is absolutely doable for a backyard mechanic, but patience is the key for those hoses. It is also helpful if you have a second person to help line up the steering column from the top while you are pushing the box up from the bottom.
Old Oct 4, 2003 | 09:40 AM
derrickk's Avatar
Thanks!
But, patience? What the H$^# is that? :-)
Old Oct 4, 2003 | 07:40 PM
EvilCartman's Avatar
Car: '82 Z28
Originally posted by derrickk
Thanks!
You can buy a 6 pack of patience at the store
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
