Tie rod sleeves
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Tie rod sleeves
Does anybody know the length of the tie rod sleeves used on 3rd gens and also what size the threaded part of the tie rod and parts are?
don't have a clue , but hotchkis sells them and now so does edelbrock , maybe you can find the numbers you're looking for on their sites.
btw, if you plan to buy stock units from autozone or some parts store I would recommend you spend a bit more on the hotchkis pieces , they are awesome quality and your alignment guy will love you , lol
... before I get banned for the 57th time I would like to say I'm in no way associated with hotchkis perf, just expressing my opinion :-/
... Thread Starter
Car: 82 Z28
Transmission: TH350
I was wondering because i was going to buy them here http://www.colemanracing.com/section/index.htp?id=636 I just needed to know what size to get. The are alot cheaper here than Hotchkis or Edelbrock for that matter.
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
I noticed they only do a right hand jam nut.Unless anybody can get a left hand nut they are no good.Great shame as they look great and are very cheap.
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Yes they make both the right and the left hand. They are under the fasterners section, it took some work but I did find them.
http://www.colemanracing.com/section/index.htp?id=651
Jegs has them in packs of 5 too.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
thats great news, i was just looking at the hotchis and edelbrock ones, banging my head at paying $50 for a piece of threaded tube!
Car: 1990 Camaro RS
yeah, i just ordered tie rod sleves (steel, if you look the link posted was for aluminum, but they make the tie rod sleeves in steel also) and 4 jam nunts.
Car: 1990 Camaro RS
the LCA's there only seem to be the tubes. so plop on and extra $80 or more for the bearings for them. you will also need to find a solution for the bearing spacers so you can mount them. and then you also need some jam nuts.
There's a site documenting how to build your own LCAs. I read that quite some time ago, but completely forgot about it when I was ordering parts for my front end rebuild. The spacers can be made from aluminum tubing. The rod ends comprise the bulk of the cost.
http://www.jonaadland.com/Z28/Mods/...uminumLCAs.html
This was also posted again, recently. Save some $$. There's a section on that site for building your own PHR too.
Car: 1989 Firebird
Engine: 5.7 LS1
for some reason that link didn't work for me but I was able to find it.
here
175.84 for all steel LCA's not bad, thats both of them, tubes spacers, ends.
here
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
At least I won't need to spend $300 on LCAs.
