88 9-bolt disc e-brake, will it ever work??
Old Jul 22, 2003 | 12:00 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey gusy i have an 88 9-bolt 3.27 posi rear and its disc, when i put it in my car i bougth new e-brake cables and i just put in new pads and i adjusted the shlt out of the e-break and it still barely works. its really hard to pull up and barely holds the car ona slight incline. now are these e-brakes defective or can i actually do something to mak it work? also if any1 moded theres and made it work let me know. thanks
Old Jul 22, 2003 | 01:06 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Have you done a search for the recall kit? You probably need to do it to get those '88 calipers to work. Or you could switch over to the '89 and up PBR/1LE style and be done with it.
Ed
Old Jul 22, 2003 | 08:49 AM
Steve89GTA's Avatar
My 89 rear emergency brake doesn't work at all.
The levers actually extend on their full range of motion. When they are all the way over, the pushrod is barely pushing on the pads...
Old Jul 22, 2003 | 11:11 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
the parking brake doesn't work my 88' either. i have the 89 setup on there though. i'm lucky i don't have a stick, if not i'd be screwed.
Old Jul 22, 2003 | 11:55 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hmm...
I have a 83 car with about a 91 or 92 rear in it. Should be the same brakes as your 89, the PBRs.The parking brake (these cars don't have an "emergency" brake, whatever that would consist of, only a parking one) works just fine. No problems. It will hold the car, even facing uphill, on a fairly steep incline. The adjustment is not too far from the mid-point of the threaded area, which looks fairly nominal to me.
Are you sure your calipers are working correctly? Everything slides on everything else like it's supposed to?
Old Jul 22, 2003 | 11:57 AM
Steve89GTA's Avatar
Pad wear is normal and even back there - on both sides.
At first glance, it looks like my 'pushrods' on the calipers are too short.
I'm gonna try fabbing up somethin a little longer..
Old Jul 22, 2003 | 02:23 PM
ebmiller88's Avatar
Interesting...I once had a set of calipers from a '93 or '94 car and I swear the pushrods are a bit longer than the ones in the '89 calipers. Or maybe those were from a 'Vette, I can't remember. Maybe there's a slight difference in them??
Steve, can you measure the pushrod and post what you get?
Ed
Old Jul 22, 2003 | 02:27 PM
Steve89GTA's Avatar
Sure, I'm taking it apart tomorrow evening and will post it then...
Old Jul 24, 2003 | 06:19 PM
Spdfrk1990's Avatar
My pre 89 9 bolt e-brake wont work also its real hard to pull up any just like u described. Im goin switch to the newer pbr's tho. I would like to know why it doesnt work tho. I was think maybe somethin about the pre 89 cars r different??
Old Jul 8, 2004 | 03:28 PM
Z28GEN3's Avatar
wow old thread
I have this same issue with my rear brakes i have adjusted the e brakes till im blue and they wont grab enough rotor to keep the car from rolling. being i have a stick i think i need to have this working. i thought that the calipers on 9 bolts would eventually ratchet themselves tight on the rotor? its tough to pull lever now, i didnt have this problem with my 10 bolt.
Old Jul 8, 2004 | 08:59 PM
Car: 89 Formula
Engine: Carbed 5.7
it will never go away, Its just a faulty design. I had brand new cables and no matter how hard you pull on the lever it doesn't work that great, I had mine to the point where it would hold on a slight incline but i always put it in gear just to be safe. as long as the brake holds it a little it will keep the strain off the trans and you will be ok. The drums on the 10-bolt that i have feel like racing brakes compared to the 9-bolt disc, and the e-brake will lock up the wheels.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
gta90
Sep 15, 2015 04:00 PM
