Drop Zone
Old Jul 24, 2003 | 12:43 PM
Grimaldo's Avatar
Drop Zone
I have 18X8 rims all the way around. My car is high right now because I also have 255/45's all the way around it. I want to know how much I can lower it without having to pound out any fenderwells or anything. I do know I will have to get smaller tires up front, I might be able to keep the same size I have now in the back. But how far can I drop it to look sharp and what size tires will I need to use?
Old Jul 25, 2003 | 12:52 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
If you plan on dropping the car more than one inch you should look into a camber kit and an adjustable torque arm for starters.
Old Jul 25, 2003 | 04:33 PM
Grimaldo's Avatar
what exactly is a chamber kit? What will the adjustable arm do? I am just worried about pouning out the fenderwells. I am thinking about going 255/45/18's in back and in front 245/40/18 in the front. Maybe smaller in front.
Old Jul 25, 2003 | 06:00 PM
wm_sorg's Avatar
When you drop car the suspension angles change. The camber kit allows the cat to be alligned to factory specs. The adjustable torque arm will be needed to correc the pinion angle. I also forgot you will need an adjustable panhard bar to keep the AXL centered.
Old Jul 25, 2003 | 06:32 PM
Grimaldo's Avatar
Is all this expensive? I dont have a cat. I thought some springs and good shocks and I would be good to go.
Old Jul 27, 2003 | 10:44 AM
FLYNLOW92rs's Avatar
I have 17 inch rims with 45 series tires in the front and 50 in the back.....
Also using the Drop Zone springs, haven't had any issues yet.......
I just got an alignment done after i lowered it and also haven't had any issues yet......
Old Jul 28, 2003 | 06:13 PM
Grimaldo's Avatar
How much of a drop is it? Did you have to change pan hard bars and all that other stuff or did you just put springs and shocks?
Old Jul 30, 2003 | 10:40 PM
Sleepy Z's Avatar
Car: 97 Camaro
Axle/Gears: 9" w/3.50 gears
I also have dropzone. i lowered the front 2.5 inches and the rear 1.75 inches. i have gabriel gas shocks...but i wish i had KYB. o well. i also have a panhard rod in the mail. i haven't yet drove the car but looks sweet.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
