When installing sway bars.......
Old Jul 26, 2003 | 11:28 AM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Hi, I just wanted to know if you could use ramps to keep pressure on the tires? I mean instead of using a jackstand under the a arm to keep load on the suspension. Can this be done with the rear sway bar as well? Thanks if you guys can help! Eric
Old Jul 26, 2003 | 06:41 PM
flyway190's Avatar
I'm sure everyone has their own opinion about ramps, personally I don't use them. I just jack up each end of the car and put some big bricks under the wheels.
Old Jul 31, 2003 | 11:24 AM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
As to your question, im sure you can, but when I did the rears (which rusted right off), I used jackstands. Whatever floats your boat.
Old Aug 3, 2003 | 10:37 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
rhino ramps work great... and our cars actuall roll onto them without hhitting anything... (usually).. plus they are cheap and really strong and light. i use them just as often as i use my jackstands... matter of fact, somtimes i use them on half the car and hold the other half with jackstands so i have plenty of room under there....
but i dont feel safe under thoes stamped steel ramps... thoes scare me. if you do end up getting some, be sure that they have a brace bar across them, and arnt just a stamped piece of steel...
flyway190: be careful if you are using cinderblocks.... they can and do collapse under the weight of a car.. they wernt designed for that.
Old Aug 3, 2003 | 12:07 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Yeah I use the rhino ramps! So I guess that will work out OK! Thanks. Eric
Old Aug 3, 2003 | 01:39 PM
flyway190's Avatar
That's true, but I use solid landscaping bricks that are bigger than normal bricks and more dense than cinderblocks.
Old Aug 3, 2003 | 03:37 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
mmmk..
hey. you're in Dallas... by any chance are you in NTTGA?
Old Aug 3, 2003 | 06:02 PM
flyway190's Avatar
I'm not actually.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
