Do I need to change the Proportioning Valve
Old Aug 7, 2003 | 05:16 PM
firebird81's Avatar
I have recently purchased a rear end out of a 95 camaro. It has 3.42 gears in it and it is a posi with disc brakes. I got the E-brake cables. I am trying to research the problem with the proportioning valve. I could not get the proportioning valve. Will my proportion valve work? Anybody used the drum brake proportioning valve? Is there anything I can get or do to make it work?
By the way I am swapping it in a 86 trans am with drum brakes.
Old Aug 7, 2003 | 08:39 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You will need a new proportioning valve for the rear disc brakes.
Old Aug 7, 2003 | 10:33 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Since you have an '86, you will need P/N 14089496.
Ed
Old Aug 9, 2003 | 08:46 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
Hi,
I bought used Baer rear discs for my 84 3rd gen 10 bolt rear. Would I use the same proportioning valve part number above?
Thanks,
Craig
Old Aug 10, 2003 | 06:36 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
What P/N would I need to put a 2000 disc rear in my '90 which currently has drums in the rear? Thanks.
deracer
Apr 11, 2016 12:04 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
Out-Cast
Aug 17, 2015 10:57 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
