Need info on Swapping 89 rear disc brakes to 87 rear end
Old Aug 9, 2003 | 10:08 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Well guys, my posi went out and I have had a mint 9 bolt rear from 87 with disc that I wanna throw in place. But I want to keep my 89 iroc rear disc brakes. I need to know what is involved in the swap. In the end I wanna have the 87 rear with 3.27 in place with my 89 PBR brakes on the 87 rearend. I have heard that the swap requires some fabbing and I would like to know so I can get this project underway. Thanks fellas
Will
Old Aug 10, 2003 | 01:52 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Both rears are 9 bolts right? You're all set! It will all swap over. Just pull the axles, switch the backing plates over from rear to rear, and swap all the brake stuff over. Easy as that.
Ed
Old Aug 10, 2003 | 02:26 AM
norcalz28's Avatar
Awesome, thanks man. Can you give me an estimate on how long it would take to do this job? Also where can I get a speedo gear to correct the gear change from 2.77 to 3.27
Will
Old Aug 10, 2003 | 05:21 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
1989 rear 11.655 rotors & alum PBR calpiers on 87 IROC.
Old Aug 10, 2003 | 04:49 PM
ebmiller88's Avatar
I'd give you 4 hours if you're fairly inclined and have the basic tools.
New speedo gear ratios are found here:
www.700R4.com
Ed
Old Aug 10, 2003 | 06:33 PM
norcalz28's Avatar
i am not too familiar with posis, and what not. do the axles simply unbolt by the backing plates? Or is it more complicated IE taking off the rear end cover and the pinion to get to the key inside? I haven't dealt with rear ends much, I am hoping its not the later. Thanks fellas
Will
Old Aug 10, 2003 | 06:46 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
9-bolt rears don't use C-clips like the 10-bolts do. You just unbolt the plates and slide them out.
Old Aug 10, 2003 | 06:47 PM
norcalz28's Avatar
****!!!!!! You made my day!!! Thanks guys, dunno what I woulda done without ya
Will
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
