torque are bushing ....HELP!
Old Aug 9, 2003 | 09:26 AM
eddie jr's Avatar
torque arm bushing ....HELP!
I just got an energy suspension torque arm bushing and am about to put it on. QUick Question though, where do you grease it??? THe instructions say to grease the inside. Does that mean in the hole where the bar goes or on the surfaces that will be covered by the mount??
thanks.
Old Aug 9, 2003 | 11:06 AM
eddie jr's Avatar
anyone???
Old Aug 9, 2003 | 12:31 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
If you're talking about the white lube that comes with it I applied it to the torque arm and then pushed it into the bushing.
Old Aug 9, 2003 | 04:32 PM
eddie jr's Avatar
ok, thanks.
Old Aug 10, 2003 | 07:35 AM
eddie jr's Avatar
How the heck are you supposed to put the bushing on? When putting the outer bracket over the bushing, I am pushing with all my might and cannot get it to touch the inner bracket so that I can put that top bolt in.......ahhhhh!
Are there any tricks that anyone else uses that may help me out here???
thanks.
Old Aug 10, 2003 | 08:27 AM
Rage13's Avatar
Car: 89 Firebird
lol, had the same problem, get 2 small c-clamps, 1 to close it together and the other to move the bolt hole up and down
Old Aug 11, 2003 | 11:48 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I used a big pair of channel locks (aka "tounge and groove pliers") to keep the metal shells squeezed together as I bolted the torque arm bushing back up to the trans.
I also applied the grease to the outside of the torque arm bushing, where it touches the metal sleeves. I didn't want any squeaking- and so far, so good (did this job in 1998).
Old Aug 11, 2003 | 01:27 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
I did the same, greased the inside and outside. Make sure you don't have it in backwards or the clamshell will never close (I tried..).
I actually threaded the bolt on before inserting the tourque arm in mine, and that made it a little easier. I could see where it was binding and make sure it was centered properly.
HTH!
Old Aug 11, 2003 | 03:49 PM
eddie jr's Avatar
well, I finally got the bugger on yesterday morning. What a pain in the butt Everytime I squeezed her closed the holes wouldn't line up. A combination of the channel locks and clamp ideas seemed to finally do it for me. I never want to take that thing off again!
thanks for the tips.
Old Aug 11, 2003 | 09:36 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
At least you know there's no slack in the bushing.
Old Aug 12, 2003 | 10:13 PM
eddie jr's Avatar
ok, here is a weird inrelated question out of curiosity. Have any of you who have put in this poly bushing noticed more vibration into the body from the engine????
Old Aug 12, 2003 | 10:23 PM
Rage13's Avatar
Car: 89 Firebird
yes, i've noticed the same with mine.. but my motor mounts are close to shot too so...
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
