How hard is it to replace rear drums?
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Mine are rubbin VERY close to the metal. Just wondering if it would be easy enough to do myself, or cost effective to just take it somehwhere to have done? Thanks,
Car: 1990 Formula
Transmission: WC T5
I would recommend a drum brake tool kit. Like a set of plyers with a hook on the end.
I perfer to do drums over disks. Dont have to wrestle with rusty bolts. Usually it takes me 5 minutes to do total once the car is up in the air.
Shoes cost 9.95, for lifetime shoes
link to tool type
http://www.partsamerica.com/PartDeta...egoryCode=3380
link to tool type
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
If you've never done it the hardest part is getting the springs back on right. Just keep track of what goes where and you'll be fine.
Definitely get that tool, or one like it. Your knuckles will thank you.
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Since you haven't done brakes before, one bit of advise for you.
Pull both drums off, but only take apart one side of the brakes at a time. This leaves you a perfect example on the other side of how things go together if you happen to encounter a problem.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i was going to say the exact same thing... i still do that, and i must have done 3rdgen drum rear brakes 8 times now...
also if the brake cyl looks wet, CHANGE IT NOW, before it blows and you almost hit somthing....... they're cheap anyway. (and if you do one side, do yoursef a favor and do the other)
AkDrifted
Aug 17, 2015 07:45 PM
