Let's see some torque arm's!
Old Aug 15, 2003 | 06:49 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Now THAT is a torque arm!
Old Aug 16, 2003 | 01:20 AM
MdFormula350's Avatar
wow thats crazy, everything looks heavy duty.
does that thing even use rear shocks?
Old Aug 16, 2003 | 09:54 PM
Hunter Motorsports's Avatar
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
Its not even a ThirdGen - its a MUSTANG
Old Aug 16, 2003 | 11:39 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
No shocks, no springs. That set-up looks frightening - like an accident waiting to happen.
Old Aug 17, 2003 | 08:50 AM
guza's Avatar
Car: 1985 Berlinetta
Engine: 305 4BBL
All that beefing up and no HP to the rear wheels.
Note: When trying to lighten the car, do not discard drive shaft
Old Aug 17, 2003 | 11:47 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Isn't that the first gen Camaro the someone is putting an entire Ford drivetrain in? As for shocks, I am sure those rods are only in there for mock up purposes....
Old Aug 18, 2003 | 12:20 AM
EvilCartman's Avatar
Car: '82 Z28
Took this back in November when the old TH400 was still in. Since swapped it out for a better one.
Old Aug 18, 2003 | 10:13 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Yea, there is no way I could use a spohn tq arm on my car. They six-speed crossmember and mufflex y-pipe for long-tibe headers would be all in the way. I'll probably go with random tech. for a tq arm.
The pic I posted is not a mustang. It's a 67 Camaro.
Old Aug 18, 2003 | 12:12 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Edelbock. Certainly better than stock, but nothing special.
JamesC
Old Aug 18, 2003 | 02:01 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Cool, keep 'em coming! Anyone have pics of the Random tech or the BMR arm installed?
Old Aug 18, 2003 | 08:00 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
I have something better coming soon........Can you say Tri-link
Old Aug 20, 2003 | 03:37 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Anyone have random tech or a BMR arm?
Old Aug 24, 2003 | 11:24 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
where'd you get that edelbrock arm? and how much was it? does it hook up in the stock location on the tranny? because i have to run a custom tranny crossmember to clear the my exhuast.
Old Aug 24, 2003 | 11:33 AM
JamesC's Avatar
The Edelbrock was from Summit, part # EDL5280 (black only. Mine was powder coated). The cost of $169.69. Fits the stock mounts.
JamesC
Old Aug 24, 2003 | 01:27 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
JamesC how good is your edelbrock torque arm over stock? Did it help with traction? I just added the Hotchkis LCA's and Panhard rod, Spohn LCA relocation brackets on the way. I still spin both tires when I nail it at 20mph.
Old Aug 24, 2003 | 03:37 PM
JamesC's Avatar
By virture of its tubular construction, the Edelbrock is obviously stronger than the stamped steel of the stock version. I can't really comment on traction since I'm not a slam-it-to-the-floor kinda guy.
JamesC
Old Aug 25, 2003 | 06:27 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
That Edlebrock setup looks fairly stout. I run with the Random Tech arm, no pictures, yet.
Old Aug 25, 2003 | 07:10 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Originally posted by PF Flyer
... that first picture shows a Watts Linkage setup, not a torque arm.
there is too a torque arm there, along with a watts link, and control arms.
Old Aug 25, 2003 | 07:35 AM
cerice's Avatar
question for JamesC
Sorry to get off the subject, but this question is for JamesC.
I was wanting to know what size your rear sway bar is in the picture. You can email at riced4@***.net if you like.
Thanks,
Chad
Old Aug 27, 2003 | 09:56 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
ANOTHER edelbrock this is on my 84Z.W/ borg 9-bolt,S.C.R. aluminium LCAs & panhard rod,Hotchkis Rr 1in swaybar.Groundcontrol adjustable Rr springs.blah blah blah.
Old Aug 29, 2003 | 08:55 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
here we go....
oops i dont have a torque arm
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
