springs to high on front susp
Old Aug 21, 2003 | 11:12 PM
thehagg
Guest
Posts: n/a
i have a 84 camaro that a friend of mine put springs in. my 84 springs were bent so he swapped a set from a 89 rs. i replaced control arm bushings, ball joints, sway bar bushings and links, put a wonder bar in. even after motor and tranny went back in yhe car it still sits high. My struts are all the way out any suggestions as to what went wrong? someone told me the springs might be upsidedown.
Someone please Help
Old Aug 22, 2003 | 01:41 AM
Kandied91z's Avatar
you shouldn't be able to put the springs upside down....if they are the right ones. however, if they aren't rated right then there's a problem. how high is too high?
Old Aug 22, 2003 | 01:58 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
how long has it been since the motor and trans went in? it took my car about two weeks to settle back down to normal ride height with the stock springs after my engine swap...
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
Dialed_In
Aug 20, 2015 01:45 PM
TA8487
Aug 11, 2015 09:02 PM
