Front drag spring alternatives?
Old Aug 25, 2003 | 03:04 PM
tpi_roc's Avatar
Does anybody know if any other (any make/model) car out there with a lighter front end than a thirdgen happens to use the same dimension springs?
I'm looking for "Drag spring" alternatives for the front end and V6 springs are still a tad heavy, moroso's drag springs are 220lb/in so something roughly in the ~300 area should work
Anywho just seeing if anybody knows of any cheap options
Old Aug 25, 2003 | 10:48 PM
Kandied91z's Avatar
i see you have it figured out..
Old Aug 25, 2003 | 11:20 PM
tpi_roc's Avatar
Re: Front drag spring alternatives?
Old Aug 25, 2003 | 11:27 PM
tpi_roc's Avatar
Also...
"The stock 3rd gen front coil spring rates are around 350lbs/in for base cars, and around 548 lbs/in for IROC-Z /WS6 cars"
If this information is correct a v6 spring would be 350~ ?
300 was down from 350 (v6) and up from 220 (moroso, too extreme for my car)
seeing if anything might exist in the same height and width as a thirdgen but even lighter rates than a v6.
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
TA8487
Aug 11, 2015 09:02 PM
