Need E-Brake help using '98+ LS1 rear
Old Sep 7, 2003 | 11:15 AM
Scott C-2
Guest
Posts: n/a
I have a '98+ LS1 disc brake rear end under my '92 Camaro. I had an auto trans, so the e-brake was never a concern, but I now have a T-5 and really need the brake.
I have already heard that the LT1/'97- would have been easier to setup, but does anyone know the scoop on setting up the e-brake on a '98+ disc rear?
All of the stock stuff is rusty, so I'd like to replace it all, but the rear has brand new brake lines & brackets installed. What parts do I need to finish the job correctly?
TIA
Old Sep 12, 2003 | 02:42 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
There is no kit avail to set up ls1 rear ebrakes on a 3rd gen. You can use the ls1 ebrake cables and fab up a bracket to tack to the car. Then its just amatter of hooking up the cars ebrake handle cable. These links may give you some ideas
https://www.thirdgen.org/techbb2/sho...hreadid=186691
https://www.thirdgen.org/techbb2/sho...hreadid=174648
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
