e brake cable on a 4th gen rear
Old Jun 21, 2003 | 01:29 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i doin the swap over to a 4th gen rear end and i really have no clue onn how to hook up the new e brake cables. anybody have pics or anything else nething is welcoe at this piont.
Old Jun 22, 2003 | 07:13 AM
MartinCadek's Avatar
it is car specific , do a search , some people opted to make a L shaped plate with two holes for the cables , others bought different length cables
here's what I did... mine is a 85TA/V8/auto
my cables were too long (4th gen rear from a 95firebird)
the bracket that holds the two cable ends slides over a long adjustment bolt , at the end of the bolt is a square part where you can hold it with a wrench, and it also acts as a bumpstop for the bracket , well if you remove the bracket and drill the hole out a little bigger you'll be able to slide it about an extra inch back , not the ideal solution but that's all I needed to get my ebrake adjusted, of course then they hanged and banged on the driveshaft so I used to homemade brackets to hold them to the tranny tunnel , or you could ziptie them to the two little tabs that are already welded to your tranny tunnel.
hope this helps.
Old Jun 22, 2003 | 07:14 AM
if you're desperate let me know, I"ll try to take some pics for you
Old Jun 22, 2003 | 11:27 AM
Engine: peanut LB9
i got it guys
i took another pice of wire and 4 crimps ad did it i'll take pics if u guys want.
Old Jun 22, 2003 | 06:49 PM
_max_'s Avatar
HELP i need pics
Old Jun 22, 2003 | 08:11 PM
Engine: peanut LB9
ok i went down to sears hardware and bought some 3/32" s/s cable about 2-3 feet will do. i bought 3 feet so i can mess around. i also 6 crimps just in case. you only need four. i took the cable and made a really tight loop around the old cable. then i crimped it so it would not come out. then put it in the old braketr and made a make on where it is. took it out and made another crimp in the cable. then putit up there to make sure i did it ok, once that was doen i made another installed them and then tightened up the old braket. good as new. i can't test them out cause i'm waiting for the shocks to get here. and gotta go pick up the brakle rotors.
Old Jun 22, 2003 | 08:12 PM
Engine: peanut LB9
sry wrong pic- try this again
Old Jun 22, 2003 | 08:13 PM
Engine: peanut LB9
another
Old Jun 22, 2003 | 08:19 PM
Engine: peanut LB9
another
Old Jun 22, 2003 | 08:22 PM
Engine: peanut LB9
thats it. i dont have any pics of the crimps from the back of the braket but i can get them if you want. i did them a little differnet. just ask and i wil take them for ya. its no problem taking them cause i have a pit and the car is jacked 20" off the ground right now.
Old Jun 22, 2003 | 08:28 PM
Engine: peanut LB9
i lied one more pic
Old Jun 22, 2003 | 08:49 PM
_max_'s Avatar
thank you
Old Jun 22, 2003 | 08:55 PM
Engine: peanut LB9
no problem, if u got nemore questions or anything hit me up on aim. twisted7xxx
Old Jun 29, 2003 | 06:42 PM
_max_'s Avatar
worked like a champ thanx again for the knowledge :hail:
Old Jun 29, 2003 | 06:47 PM
Engine: peanut LB9
just got my car done about an hour ago and its running so great
and i really like the stance
the *** is a lil all over the road but its ok
Old Sep 11, 2003 | 08:18 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Is there any way to loosen the brake cable? As you can see in my picture there is about 4 inches of distance between the cables and the t-bracket they need to reach. Jusding from the picture I seem to have less slack from the brake lever.
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
