driver side 1Le brake carrier
Old Sep 13, 2003 | 03:29 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i just bought a kit from a lady on ebay, all hardware, adapter plates, every bolt washer , passenger side carrier, but no left handside one. i realize from usin the search it might be damn hard to find this carrier. but does anyone have any inside info about where i can get one from?
Old Sep 13, 2003 | 08:31 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Try contacting Steve Spohn. He has 1LE carriers.
Old Sep 13, 2003 | 08:35 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
i just need the LH side tho. he wants 195 bucks just for both. think he will sell em individually?
Old Sep 13, 2003 | 08:43 PM
alloy's Avatar
Car: 87 IROC-Z28
Well all you can do is ask. Nothing ventured, nothing gained.
Wait till Monday though, he's not going to be near his computer this weekend.
Old Sep 13, 2003 | 10:16 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
sounds like a plan, thanks.
Old Sep 15, 2003 | 10:10 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
talked to steve spohn, no go on that idea. anyone know where i can get a LH side carrier? this sucks, if worst comes to worst ill sell the RH side one and buy a pair from spohn.
Old Sep 16, 2003 | 03:58 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
hmm, 88-96 C4 brakes have the same carrier correct? if so i think i found one. will this work? and the dual piston PBR calipers are the HD or standard brakes on the c4?
http://www.corvetteamerica.com/main....TOKEN=53730374
Old Sep 18, 2003 | 10:29 AM
Br1dgeman's Avatar
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
Not too sure on if bolt spacing for the corvette caliper is the same as the 1LE. I have corvette carriers, I can measure one, what is the spacing between the bolts on your carrier?
Old Sep 18, 2003 | 01:32 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
ill let u know when i get the kit i got thats missin the LH side carrier. im still waitin for the kit in the mail
Old Sep 19, 2003 | 10:41 AM
Br1dgeman's Avatar
As I am sure you have now read in your other post, the C-4 carrier is not the same as the 1LE carrirer.
I tried mocking up a C-4 caliper & carrier using a modified spindle & 1LE rotor. I don't think you can place the caliper in the same location as the 1LE- too much interference to get bolts in there to work.
Back to the drawing board.
Old Oct 2, 2003 | 12:17 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
i got the stuff in the mail finally. i really need to find a LH side carrier. ill even do this... if anyone out there needs a RH side on ill go halfway on a pair from spohn OR buy the pair from spohn and sell u the RH side carrier i have right now.
Old Oct 2, 2003 | 04:47 PM
subsonic9's Avatar
Car: 86 IROC
Transmission: WC T5
Good luck getting rid of the rh cradle. I was in the same boat and ended up giving the thing away on ebay(I think for $25), Then bought the set from Spohn.
Old Oct 2, 2003 | 06:02 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
i know man this sucks
Old Oct 6, 2003 | 01:07 PM
Parrydise7's Avatar
Check with SSBC. They sold me the one carrier individually, but it is going to be pricey.
Old Oct 6, 2003 | 02:32 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
did u buy it over the internet or on the phone?
Old Oct 7, 2003 | 11:01 AM
Parrydise7's Avatar
I ordered it by telephone. If you have a problem (for instance they don't know the p/n) let me know. I'm sure I've got it somewhere, although it may take awhile to find.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
kyleb24
Aug 15, 2015 08:24 AM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
