about GTA wheels...
Old Sep 14, 2003 | 10:11 AM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
about GTA wheels...
ok guys i've been thinking about something...i've noticed on most cars that the rims with an offset (deeper rims) are on the rear and the rims with no offset are in the front. then i looked at my GTA. for some reason, GM put the deeper rims on the front and the zero offset in the rear. does anyone have a clue why they did this? is this bad? i was thinking, if it's possible, to just switch the rear tires to the front and the front tires to the rear. can this be done? do i need spacers?
Old Sep 14, 2003 | 02:52 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I believe they have different off sets to them is so they can fit a 8 inch rim and clear the steering componits, or something ike that. As for switching them from front to rear it can't be done.
Old Sep 14, 2003 | 04:30 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
when i bought my GTA someone had rotated the left side wheels. so i had the rear right wheel on the front right...this was bad. the steering rubbed the lip of the rim on the inside...made a nice big groove in my honey combs . i switched them and it was fine. DONT ROTATE THE WHEELS!
oh and also...stock GTA wheels are 245's. doesnt 245mm = 9.5 inches?
Old Sep 14, 2003 | 04:56 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
yes, 245mm does work out to be 9.8 inches, but the rims aren't that wide so there must be something that you aren't accounting for. The rims are 8".
I figured this out because 300mm = 12 inches. Hence, 25mm per inch. 245mm / 25 = 9.8inch.
GTA rims are 16x8". Don't forget that the stock 245mm tires on GTA rims stick out a bit beyond the lip of the rim.
Old Sep 14, 2003 | 09:24 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
25.4mm per inch actually.
245mm would refer to the section width, which is not the tread width. Tread width is a different measurement.
Old Sep 14, 2003 | 09:27 PM
FruityOne's Avatar
Fine, be that way.:lala:
Didn't know there were 304.8mm per 12"
Old Sep 15, 2003 | 11:13 AM
Engine: carbed L98
i always just use 2.5cm per inch...easier that way if i dont have a calculator
Old Sep 15, 2003 | 12:29 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Seriously, do some searches. This is something you can find more information on than you would ever want.
But to give it a quick overview:
Front 16x8 thirdgen rims have a 0mm offset - as in the mounting surface of the rim is exactly in the middle of the wheel. Rears have a 12mm or 14mm (I think.... been a while since I needed to know) offset - as in the mounting surface is moved out from the middle towards the outside of the wheel. This brings the wheel in tighter to the car when mounted. There are many things at play here like rear axle width and front track width of the suspension. The rims are not designed to be interchangable front to rear and if you have directional tires, you are screwed - no rotating. You can run a front wheel on the rear but it will just make the tire stick out farther and make the car look quite gay.
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
