Tubular or Boxed SFC's?
Old Sep 15, 2003 | 08:59 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Which would you consider to be better or stronger? Any help would be great, thanks. Oh yeah, i am talking about weld-ins of course! thanks
Old Sep 15, 2003 | 11:38 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
tubular isnt supposed to collapse as much as boxed stuff goes but i dont really think it would matter all that much unless you are putting out gobs of power that will really twist the car.
Old Sep 15, 2003 | 03:10 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Tubular is around 14 lbs lighter than boxed type.
Tubular is slightly stronger due to no sharp bends like the boxed type.
Anyway, let's not turn this into an engineering debate. The bottom line is either type/size tubing is overkill for the application. It doesn't matter if you weld in a 1.5x2.5 SFC, or a 1.75 tubular SFC, either one is gonna lock the chassis together and do the job we want it to do. We're not building Abram's tanks! The actual goal is to have a piece that will adequately tie the frame together, and not weigh any more then necessary. -Steve Spohn
PS I'm running box'd Spohn SFCs and other suspension stuff. I like them... bottom line Spohn makes his stuff to last.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
