Rebuild or Reman:That is the question
Old Sep 18, 2003 | 02:05 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I just received a pair of PBR rear brake calipers I purchased through the classifieds section here at TGO. They came with rotors,e brake cables and even Earl's SS flex lines attached to the calipers along with every nut and bolt needed. My question is should I rebuild them or turn them in as cores on a pair of reman units? They were sitting for a while so I'm not 100% sure that they are still useable. Any thoughts?
Attached Thumbnails Rebuild or Reman:That is the question-mine.jpg
Old Sep 19, 2003 | 02:51 PM
Mongoose's Avatar
Car: 90 Formula
Anyone?
Old Sep 19, 2003 | 03:08 PM
BADBIRD009's Avatar
i would check to see if the rotors can be turned. if so, i would rebuild the PBR's.
Old Sep 19, 2003 | 11:41 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You can find rebuild kits through places like expressautoparts.com and carparts.com if you want to rebuild them yourself... then at least you know it's done right. But that's just coming from me... I don't trust places.
Old Sep 20, 2003 | 12:40 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I'd compare prices of rebuilt calipers to the rebuild kit and see which seems most economical. Most parts stores offer a lifetime warranty on the calipers.
Old Sep 21, 2003 | 09:57 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
calipers
id say if they're not all corroded, and the piston pushes back in the caliper w little force id run them as is. if the piston wont go, i'd do the reman unless your experienced at rebuilding calipers.i bought reman from a/z for frt 1le for like 32$ ea (and they were new) as cores aren't avail
Old Sep 21, 2003 | 12:49 PM
Mongoose's Avatar
Car: 90 Formula
Well,it looks like I may be going the reman route. I was disassembling the parts yesterday for cleaning and paint and to examine the calipers and found that one appears to be good but the other seems to be frozen. Being that I'm not that experienced with brakes beyond replacing pads and getting rotors and drums turned I'm all up for taking the easy route. Sounds like a contradiction considering I'm swapping the rear end out and switching from drum to disc brakes at the same time.
InfinityShade
Feb 21, 2016 01:29 PM
ydnar417
Sep 23, 2015 05:57 AM
fbirdroller
Sep 2, 2015 10:27 PM
redmaroz
Aug 16, 2015 11:40 PM
hokis
Aug 9, 2015 03:57 PM
