Spohn sub frames bolt on??
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Do the spohns bolt on before they weld in?? I need a set that does this but I have dual cats and need as much ground clearance as possible!! The reason I need them to bolt in is I need to do some under body work next year and they will need to come out for that. Are there any other bolt in's that will fit a low to the ground dual cat car, or even a set that does not run along the rocker??
Alston SFC's may be what you're looking for. You can get a set and bolt them in for now, then have them welded when you're other work in completed. Check the TDS website above. Also do a search for Alston and you should find some pictures.
Car: 91Z
Thank's for clearing that up MD, I finally saw a pic. It makes sense how they go in. I will have to use the alstons for now, then mabey add some spohn connectors later.
Hotrodboba400
Dec 10, 2019 07:07 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
