axle shafts disk and drum?
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
i looked with no luck.
but i think this is a stupid question, but here it is....can i use my 92 DRUM brake axles in my new posi DISK rear? Or in other words are the disk axles different from the drum?
thanks
but i think this is a stupid question, but here it is....can i use my 92 DRUM brake axles in my new posi DISK rear? Or in other words are the disk axles different from the drum?thanks
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
They are different, but the drum axles can be modified to work. You have to turn the OD of the axle flange down to fit inside the disks.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Or just get rear rotors for a '93-97 LT1 car, it'll bolt right up. No fitment issues here...
Ed
Ed
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
