Need full info. 4th gen rear, gear change, drum to discs
Car: '90 Iroc
Transmission: 5 spd
I'm just about ready to put the 4th gen rear I got into my '90. I currently have 3.08 gears and this rear has 3.42's so I need to know what speedo gear(s) to get for the tranny so my speedo reads correctly. Part numbers are greatly appreciated.
I also need the part number for the prop. valve that I'll need for disc brakes. I currently have drums in the rear but the new rear has discs.
My last concern is the e-brake cables. Some people talk about cutting and welding a bracket (which I'd prefer not to do because of lack of resources) while other say they just bought a new e-brake cable and that worked. If anyone could help me out with the part number for the e-brake cable that works I'd greatly appreciate that also.
Thanks.
Brian
Thanks.
Brian
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You'll need cables for a '90-92 disc rear car, they 're only $25 or so each from GM. Ask for the cables for a '92 car w/ the perf pkg brakes, I can't find the P/N for the cables but this is what I used.
I'll get ya the prop vlv P/N today if I don't forget.
Ed
Ed
You have a '90, so:
10136840 1990-'92: M1.5 tube nut threads
Good luck!
Ed
Good luck!
Ed
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
